Not sure how the laws are in your area but in the US changing the odometer reading is a federal offense even if you're just correcting a replacement to match the original. The penalty for odometer tampering in the US is $10,000. per incident. I once had to replace an odometer on a pickup I had. It was still under warranty when it was replaced so everything was documented by the dealer and I also made notes of the change but the new odometer had a 000000.0 reading when it was installed. If you do find a way to make the change and the laws are similar to the US I suggest not making it public.
