So, i finally got it all back together and fitted nicely(haha)in place behind the center console..mind you, this was the initial run at the lowest settings..when engaged, the regulator made funny farting noises..also, i could hear the tiny tank dumping and it was cold to the touch, after i got on it a few times to see if there were any seat of the pants differences..i have to say that is does feel alot like the water/meth injection(oil pan 4)..although i was only running it at highway speeds, due to the pre injection that teoman had mentioned..still have to investigate more into this, first I've heard of such thing..that being said, it might be right were i want it, for mileage, only time will tell..I had previously read a post on tdiclub were the user said he would only change out a 1lbs tank every two weeks! If this small tank last one week i'll be shocked!
