Originally Posted by California98Civic
The difference between the thick outer radius rim and the fully cover Grimm is so modest, however, that I have to think this result might turn out to vary a little bit according to the car and the shape and design of the wheel well that needs to be ventilated.
agree 100% difference will be modest - one positive for me with not having the wheel fully covered is that you can more easily access the lugs for wheel removal, and having some ventilation will help with brake cooling.
i'm going to make a start on mine shortly... and a grille block
