Old 10-04-2019, 10:30 AM   #23 (permalink)
Shaneajanderson
Redneck Ecomodder
Alright folks, now that I have the Camry it's question time. The car has 195/70r14 tires. RE92 are 165/65r14. I'm not sure I could narrow up that much, and even if I could I don't really want to go to a shorter diameter as I'm not sure the LRR would pay off. That said, are there any other notable LRR tires closer to my stock size? (or a little taller, plenty of room in the wheel wells). I also don't want to spend a fortune, I can get cheapos in this size for $40-60 a piece, and I'm going to get a pair of winter tires and an extra pair of wheels shortly. I can probably make it to summer with two of the current tires on the back, winter on the front, then replace the rear tires I run this winter with summer tires come spring, and run the other two current tires on the rear through summer, then replace those the next spring.
Kinda rambly, but any input is greatly appreciated.
