Old 10-04-2019, 12:21 PM   #28 (permalink)
Shaneajanderson
Redneck Ecomodder
How will this car be used? I'd be wary of going with a smaller diameter if you're going to be spending any time on the highway (shorter gearing).
The current Prius uses a 195 width 15" tire. Not sure what brand, though it's obviously going to be LRR. Might be worth getting those on some cheap steelies.
Also: I assume this is the I4 engine, not the V6?
Yes I4, wouldn't buy a v6 Camry. Definitely not going smaller diameter tires either, I think I could go a size or two taller and be fine though as it has big wheel wells.
