Originally Posted by joffa
Hi Mate, I would suggest ScanGauge2 (Scangauge2.com) It is a trip computer and code reader and you can have all sorts of guages displaying info from the ECU loke Air temp Revs etc.
Be careful to check if it is going to work on your MY02 as I have an MY04 and the SG2 does not seem to connect on that model. I have an RX not a WRX and I know the WRX and STi are OK from MY04. Strange issue with the OBDII type Protocol and ECU codes for 2004.
Joffa
Australia
Thanks man. That thing is way better than anything i was hoping for.
It even turns off CELs. Mine's been on for a while since my exhaust doesn't have a catalytic converter anymore.
