Old 10-05-2019, 01:37 PM   #3 (permalink)
EcoCivic
Originally Posted by teoman View Post
It is more or less pre programmed.
Tuners can change it.
Thanks. So it normally just runs at what it is pre programmed to and only retards timing if the knock sensor detects knock for some reason? Also, presuming the recommended fuel octane is used and everything is working correctly, would the knock sensor ever detect knock under normal conditions?
