Old 10-05-2019, 01:05 PM   #4 (permalink)
oil pan 4
In older fuel injected vehicles the knock sensor was used as a kind of a fail safe to keep them running smooth, only triggered by abnormal operations causing knock.
In newer engines it seems that the knock sensor is used as a real time instrument to provide vital computer input. It allows engines to get the best fuel economy running near stochometric air fuel mix buy running up to 50 and even 60 degrees of advance.
Modern engine control systems will keep adding timing advance while cruising down the road until a little knock is detected then the computer pulls timing back.
EcoCivic (10-05-2019)
