Old 10-06-2019, 12:40 PM   #9 (permalink)
oil pan 4
If the engine uses mass air flow to regulate the air and fuel going into the engine it's more likely to actively use the knock sensor.
I think the easiest way to tell would be to use a live obd2 monitor rig get an idea of what the timing looks like. If it only ever goes to around 40 degrees or so it probably runs a fixed timing table. If it goes over 50 it's probably using the knock sensor.
Then to confirm put a few gallons of premium gas from empty in it and it should run even more advance.
EcoCivic (10-06-2019)
