Old 10-08-2019, 10:19 AM   #36 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Originally Posted by stonebreaker View Post
Storing the energy as heat is inefficient. Use the heat from the exhaust to boil water and generate steam to turn a generator and charge batteries. When the batteries are full, turn the gasoline motor off and just run on battery power.
If heat is needed, storing it makes sense. The secondary steam engine has been an obvious option for a century, but steam engines are only efficient with a much higher temperature difference, so they would dissipate most of any remaining heat.
