Get an EV and setup a "Totem" system, which uses an ICE to run a generator and catches the waste heat for domestic water heating, that way you can be sure your fuel is being utilized in an efficient manner, you can do this with gas,diesel or natural gas even propane.The advantage, one fuel source, the disadvantage equipment to maintain which if balanced by storage would last a long time.
