A smart charger is definitely required for charging, for that very reason.
Lithium batteries can use coulomb meters to measure SOC more accurately (Lithium Insights use a more sophisticated device called OBDIIC&C). If you keep the SOC between 20% and 90% you should be fine and extend the life of the battery verses discharging/charging them to 0% and 100%.
SOC is fairly easy to measure on lithium batteries with a coulomb meter, versus lead acid where the voltage varies under load. Other lithium chemistries are much more sensitive to things like temperature and charge/discharge rates.
2006 New Formula Red Honda Insight MT, 284k: ( Build thread)
2013 Ember Black Volvo S60 automatic, 101k (Fiance's car):
