Hi Freebeard,
Thank you for your help and your patience!
The NASA van photo is definitely helpful. I could easily use that as a template for what I am doing. Interestingly enough the taper on the NASA van seems pretty darn close to what orbywan used for his RV Aero mod and he had really remarkable results according to his reports.
For what it is worth I did some rough calcs on the taper of the NASA van and came up with 14 degrees. Then I went back to the oerbywan thread and while there isn't as good a photo to measure from, his taper came out by my calcs at 16 degrees - roughly equivalent to the NASA van.
Okay, feeling much more confident to give this a stab...
Thanks again, Bill
