Old 10-16-2019, 03:01 PM   #7 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I wouldn't bother with the hood height. Wipers probably won't matter either, but they're easy enough to remove. If the tires are in good shape with no cracks, I'd pump them way up for the test. Maybe 70-80 PSI? Mini spares usually have higher rolling resistance and smaller diameter. Taller LRR tires would help gearing. Getting the engine to run lean will help. Full belly pan and get the rear to match the template. Front end is probably OK, but I'd do spats in front of the tires. Can you remove accessory belts? You only need the water pump to drive 60 miles if you have a good, fully-charged battery. Weight reduction if there will be any stop-and-go or hills. Mobil 1 Advance Fuel Economy oil (0w-30, 0w-20, 0w-16). Fill it to the lower mark on the dipstick. Ethanol free regular octane if you can find it. Make sure there's no brake drag. MPGuino to test mods (if you have a good VSS). Trade it for a Geo Metro!
Pick a warm day! And try to run out of gas as you crest a big hill for a long coast!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 3 Users Say Thank You to Gasoline Fumes For This Useful Post:
Frank Lee (10-18-2019), MetroMPG (10-17-2019), Xist (10-20-2019)
