Old 10-16-2019, 08:45 PM   #7549 (permalink)
oil pan 4
Turtle
It's quite possible that draft reports were disseminated to the press before the official report release.Just so timely reporting could be made.
Also,the actual research reported would have been available to the public 24-months before the report was issued.
I get a very strong confirmation bias vibe from your reporting.Almost,if not obsessive.
The scientists are extremely careful about their claims.And first to show the weakness and recommended additional research they feel needed.I've yet to pick up any conspiritorial sense from any of the published literature.
I know the true believers aren't reading the reports and I know they aren't reading the supporting papers.
You your self had no idea what The "quantification in oceann heat up take from changes in atmospheric O2 and CO2 composition" paper was before we told you about it or that it had had been retracted in nature which means it's straight up junk science.
No conspiracy theories here. Just pointing out really obvious cherry picking. If any one counter argued with a very conveniently short 50 year time period as the base line for post industrial climate the believers would absolutely call them out on cherry picking.
I think everyone should read ipcc reports, my conformation bias does nothing at that point.
My confirmation bias didn't cause the foundational paper of the ipcc report to be retracted. It was the guys who made the paper, blame their self righteous confirmation bias.
Obviously these guys weren't very careful.
They were careless, screwed up, screwed up a lot and got caught.
So you don't want to talk about the report, cherry picking, retraction of base studies ect?
Just dodge, dodge, dodge.
My best find is a mechanical engineer. He says don't ever trust a computer model if you can't see all the source data and the programming.
The problem with mechanical engineers is the bean counters don't listen to them.
The higher ups almost always want the cheapest fastest future be damed solution the engineer can eek out.
aerohead (10-20-2019)
