Old 09-13-2008, 11:48 AM   #1 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Which Arduino Clone?
I am using an Arduino Diecimila to put together a servo actuated throttle for a hybrid generator. I would prefer to use a lower cost clone for actual use to avoid damage to the Arduino that I am using now, which is set up for learning how to use it. The clone would be dedicated to this use only and would hopefully have a long service life.
This would be a high vibration application. I would like to solder connections. Once the clone is programmed, I probably would not need to make changes although tweaking is probably to be expected.
Which clone would be a good choice for this application?
If I were to program the chip in my Diecimila, and transfer the chip to a clone, will that work? Then I would not need the usb port on the clone, just a power port.
Nissan Versa Aeromods
