Old 10-25-2019, 10:50 AM   #18 (permalink)
Piotrsko
It basically uses the exhaust heat to catalyze the unburnt fuel "clumps" in the "DPf". Problem is the temp for this to occur is above typical aluminium melting points, so they add fuel somewhere. In a diesel you have masses of extra O2, I would think they add air somewhere in a gasser.
