It's automatic transmission. No other same Gen Camry drivers on this forum?
My mpg screen shows avg mpg per minute for the last 15 minutes. It fluctuates in the current minute's mpg bar, based on how hard the throttle is depressed.
Really could use a suggestion of how high on psi for tire pressure I should run for max fuel efficiency without wearing out the tires.
