Old 10-28-2019, 11:12 AM   #1 (permalink)
Xist
90 day: 34.37 mpg (US)
My Accord wouldn't start yesterday; my battery is one year old.
Mom likes to leave me behind just before I am ready. I got to Church right after she did, but walked through the door at the same time that she did. Two hours later, my car wouldn't start. I have had slipping belts on and off for a year. I have adjusted both several times and replaced both when I changed my timing belt last year.
Both are from a dealership.
I figured that it was the alternator belt that was slipping. I grabbed my jumper cables and asked Mom to back up her boat, but someone pulled up with his Accent.
I said that I was hesitant to use a smaller car to jump mine, but he pointed out that I just needed a little help. She started up right away, I thanked him, and put my battery on the charger when I got home. The battery supposedly topped off last night, but I kept it charging all night, just in case.
This morning the alternator belt seemed tight, but the power steering belt was loose. I tightened it, disconnected the charger, and she started right away without any belt squeal.
According to The National Weather Service, while it was around freezing this morning, it was a tropical 61° when I had issues.
I guess that I will have AutoZone check the battery before I drive to the reservation this afternoon (if the family confirms).
My battery has 800 cold-cranking amps...
Batteries do not last that long in Arizona, but my car spends very little time in the bad part. I would expect the cheapest battery last over a year in Phoenix, let alone 800 CCA.
The average high temperature in Show Low in July was 88° .
