Old 10-29-2019, 10:25 AM   #4 (permalink)
oil pan 4
If they want $900 for "a car with a blown head gasket" I guarantee it has other problems.
Why did the head gasket blow?
The head gasket likely failed due to over heating.
Why did it over heat?
A failed thermostat, broken fan or a coolant leak.
Most common cause for low coolant and over heating is negligent and/or ignorance.
Most common cause for a blown cylinder head is it was ran with low coolant.
If it was ran with low coolant it probably has a cracked or warped cylinder head.
Why was it low on coolant?
Most likely cause it has a leaking radiator or coolant pump.
How long was it leaking?
If it was leaking for months then some genius was probably filling it up with tap water so the engine, head and radiator are full of scale.
I say there is almost 0 chance just replacing the head gasket fixes it.
Now I play with ice vehicles as a hobby and don't have to keep them running.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
iikhod (10-29-2019), ME_Andy (01-31-2020)
