Old 10-29-2019, 05:41 PM   #10 (permalink)
freebeard
Clarification, I am ENCLOSING an already existing trailer, and none of the existing trailer dimensions are alterable.
Got it.
The problem becomes defined by the back end. How much could you nip off the rear corners of a rectangular bed? Maybe use a perforated ramp instead of a solid one and leave the wing standing proud?
A lot depends on loading and unloading. Do you need access through the driver door?
You can have slab sides and put the radius in the cap. kach22i's two examples are good.
edit:
Some argumentation here about this design (the old faster backwards conundrum):
