Old 10-30-2019, 03:15 PM   #42 (permalink)
S Keith
Originally Posted by vskid3 View Post
I've wondered if it would be worth it to make a battery temp spoofer to not only make the fan run more, but also to have the current limits kick in a little earlier to put less stress on the battery at high and low temperatures. It could even spoof to the extremes all the time to keep the current limits low to squeeze a bit more life out of a dying battery.
As have I, but $20 for a bluetooth OBDII and hybrid assistant get it done with minimal effort.
Issue I have is that they are NTC sensors, so as temperature increases, resistance decreases. If they were PTC, just add a resistor in series, but being NTC, the only way to do it is to put a resistor in parallel, which completely jacks up the resistance/temperature curve.
Hybrid assistant is a no-brainer. Let the car manage it up to 100°F. Once it hit's 100°F, full blast cooling.
