Thread: 3 vs 4 cylinder
Old 09-13-2008, 11:29 PM   #10 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
In automotive applications, it is better to use fewer, larger cylinders than racing tradition encourages. The peak RPM is reduced, but at cruising power that is irrelevant, and there is a greater volume to surface ratio in the cylinders, and hence a smaller percentage of the charge has its flame quenched by the metal.
The diesels that get 50% efficiency in ships have cylinders bigger than some rooms, and run at 110 rpm.
