Old 11-06-2019, 10:20 AM   #3 (permalink)
EcoCivic
I would go for a Honda OEM unit and see how it works. Bigger is probably better, but how much is hard tonsay. Without testing.
Thanks. Do you have a suggestion on which Honda I should get a cooler from? An RSX cooler won’t work because of where the coolant lines come out, but an S2000 cooler looks like it might. However, an S2000 oil cooler is pretty expensive and I am wondering if it would be worth a minimum of about $70 for an OEM cooler when that’s probably almost half of what a custom setup would cost and there’s a chance it won’t do what I need it to do. Thanks
