Old 11-06-2019, 01:52 PM   #8 (permalink)
EcoCivic
There are lots of them out there actually. Typically they are labeled as oil coolers, not warmers or heat exchangers. The harder part is finding a way to mount them properly if it wasn't designed for your engine. If you stick with the Honda stuff it'll hopefully simplify that.
Thanks. I’m hoping if I get a Honda one it will screw right in. I have an extra engine in the garage to test fit it on though, so that's helpful. I know it’s hard to say, but do you think adding an OEM Honda heat exchanger would significantly improve the oil’s warmup time, or do you think the difference would be negligible?
