Old 11-07-2019, 01:49 AM   #12 (permalink)
me and my metro
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Those are designed to slightly cool hot oil down to coolant temp. They are set up the same way on the Ford gas engines I work on. The GM coolers that use 1/2” tubing to connect to the radiator are only partial flow so even if they plug up the engine will still live. I know you are looking to warm the oil quicker for fuel economy. Thinner oil may give better results in my opinion. The problems I have seen here is cold oil in fire fighting equipment and engine failure. We have installed oil sump heaters in some of the gas engine trucks with good success. I had one on a VW bus back in the early 80s to aid cold starts and faster warmups on an air cooled engine.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
The Following User Says Thank You to me and my metro For This Useful Post:
EcoCivic (11-07-2019)
