Old 11-08-2019, 12:36 AM   #26 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I've been running a set up like this for a couple of years on a three of my cars. On my 'best' set up, solar panels charge my OEM battery to 100% float every morning. The alternator sees the full battery and doesn't charge other than regen.
For the first ~6 miles the alternator just sits at 11.7 volts (no charge). After that (and several engine restarts) the ECU sees the battery as getting slightly low and starts to put a slight charge in at 12.4v. It then cycles lightly depending on how much power the solar panels produce. On a sunny day in the open it's possible to almost drive entirely alt. less.
In two years I've saved ~140k alternator Wh. That's around 11 gallons over ~12k miles (around 3%). However you trick the alt into not charging should give similar results (assuming your method has enough capacity to reduce your alternator duty cycle to around 20%). All the same, the difference is too small to pick up in tank-to-tank fill ups. 1.5% gains would likely be more typical if you can't charge at your destination.
At it's simplest, I just keep my Fiat battery on a garage mounted solar charger, that keeps the alternator off for the first few miles just the same, but I don't have kWh numbers for that one. Sure is a simple 'mod' though
The Following 3 Users Say Thank You to oldtamiyaphile For This Useful Post:
Daox (11-08-2019), MetroMPG (11-12-2019), redpoint5 (11-08-2019)
