Old 11-11-2019, 12:31 PM   #18 (permalink)
redpoint5
90 day: 29.78 mpg (US)
A friend of mine has 2x 1996 Honda Accords. He was convinced he had a fuel problem once so I helped him swap injectors. The problem didn't follow the injector. Turned out he had a bad plug wire. Anyhow, he should have started simple before assuming it was an injector issue, but at least we could rule out injectors as being the problem. It's a nice way to avoid throwing parts at a problem in an attempt to fix it.
iikhod (11-11-2019)
