Old 11-11-2019, 01:20 PM   #427 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
A few weeks back a friend backed into my car, smashing one of my headlights and slightly bending up some of the metal support structure on the driver side. Got it all fixed up, and with the new headlights I decided to switch from HID projectors to LED in reflectors for its simplicity and lower power consumption, plus maybe a marginal weight savings.
I'm pleasantly surprised by how clean the cutoff is, and the adjustment screws in the headlight housings work now so I was able to get a better adjustment and also better align the body panels, as I wasn't having to tilt the entire housing for the final fine tuning. They're not as bright as HIDs but definitely brighter than halogens. I can verify they're a reasonable choice for Insight owners which won't blind other drivers.
https://www.amazon.com/gp/aw/d/B074Y...b_b_asin_title
Edit: How to rotate attached images? They were correctly oriented on my phone.
Looks good. Have you measured the actual power consumption of the bulbs on low beam vs. high beam?
How are the low beams vs. high beams in nighttime visibility? The low beams on mine are better the original halogens (but are inferior to my mom's Prius HID low beams) but the high beams blow everything out of the water.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
