Old 11-13-2019, 02:58 PM   #1 (permalink)
drudis
Coroplast - supporting bracing for "Aero Tail" on my trailer
(Read a LOT of posts about coroplast, especially the RV with the boat tail...)
How much BRACING is required to support these 4'x8'x.156" coroplast tails behind my 6'tall x 8'wide enclosed snowmobile trailer?
Should I run just a 1"x1" aluminum angle, in the two upper corners? (Indicated in RED in photo).
And 2 more angle-aluminum in the lower corner (edge) also?
Do I need more structure, as in creating a "picture frame" of the 4 corners, and tying them all together... (pictured in BLUE)?
ID:	27170   Click image for larger version
ID:	27171   Click image for larger version
ID:	27172   Click image for larger version
