Old 11-14-2019, 10:18 AM   #20 (permalink)
Piotrsko
Originally Posted by EcoCivic View Post
Thanks. So would you say it’s okay to floor it once the oil reaches 100 degrees? Why won’t VTEC activate until the engine is warm if it’s not harmful to the engine? This car calls for 5w20 oil
Heavy acceleration yes, floor it not so much because you will still have temp differences that can cause failure. Bearing surfaces are ok however.
Actually thinking about it, this strikes me as they same scenerio of an Alaskan aircraft engine and AFAIK, they make TBO.
Unknown. Could be a emissions strategy.
EcoCivic (11-14-2019)
