Thread
A better alternator delete
11-15-2019, 10:05 AM
47
permalink
Daox
CM400E
- '81 Honda CM400E
90 day:
51.49
mpg (US)
Daox's Grey Prius
- '04 Toyota Prius
90 day:
49.53
mpg (US)
Daox's Insight
- '00 Honda Insight
90 day:
64.33
mpg (US)
Swarthy
- '14 Mitsubishi Mirage DE
90 day:
56.69
mpg (US)
Daox's Volt
- '13 Chevrolet Volt
The other night I tore the first battery pack apart. The disassembly process was a little easier than I expected. The case came apart relatively easily with a small straight blade screw driver.
Inside each case is three 18650 cells in series, and a small circuit board with the BMS on it.
I found out the BMS is a S8254A chip. It has a bunch of functionality that I am still reading up on. However, the transistors I do not think will be able to handle the amperage that this pack will see. So I think I am going to ditch them and build my own pack.
So, I continued disassembling the pack into individual cells. This also went pretty easily. The only possible issue is the welds peel up and sometimes leave some residue on the connection. I would like to find a way to clean this up better.
Current project:
The Following User Says Thank You to Daox For This Useful Post:
Xist
(11-20-2019)
Daox
View Public Profile
Send a private message to Daox
Visit Daox's homepage!
Find More Posts by Daox
