Originally Posted by Prii
I am currently brainstorming ideas for an aerodynamically clean cargo trailer to pull behind my Prius for a cross-country move. I have a basic 4'x8' flatbed utility trailer (which knocks 10-15 mpg off the Prius even when unloaded), a longer converted boat trailer and a narrower jet ski trailer. My thought is to try to keep the trailer's frontal area well within the frontal area of the Prius. I need to protect the contents from weather so am toying with building a very lightweight "poor man's fiberglass" shell. I also am thinking the bottom should be sheathed to cut down friction from the road surface. Anyone have any ideas/experience along these lines?
Time, effort, energy. A Penske straight truck with the Prius on a trailer is the better option.
The problem is
the inefficient design of the Prius. When you need it most, it’s unavailable. It’s naught but a one-trick pony.
Assuming your belongings are actually worth the cost of transportation (most persons possessions aren’t; same problem with paying long-term storage) then security from the elements AND theft both rate as highest considerations.
Thus the straight-truck/trailer combo. Insurance coverage.
Can the idea proposed rate full-replacement cost insurance?
Get that question answered. In writing.
