Originally Posted by mpg_numbers_guy
My mom runs 50 PSI on her Prius. I ran 68 PSI in my Civic. Currently running 80 PSI in my Insight. Wouldn't recommend over 60 PSI unless you're an extremist.
From what I've read/experienced, tire wear seems to be best at sidewall max, and >70 PSI accelerates wear slightly on tires. Not all cars show a MPG improvement past 60 PSI, so unless yours does don't run them past 60 PSI.
Wow, what tires are you running 80 psi on your Insight? My understanding is that burst pressure is about 4x sidewall max. I was running low 50's on my Gen2 Prius. Snapped a rear spring at one point. I don't know if there was a connection. Currently mellowed down to low/mid 40's on my Gen3.
