Old 11-20-2019, 11:14 AM   #36 (permalink)
Daox
Originally Posted by Tahoe_Hybrid View Post
is it possible to convert a old NIMH to lithium battery the peak discharge is 37.6kw and peak regeneration is 32KW (the motor is 60kw rated ) according to the EPA
I'm sure it is, but I'm also sure its probably a ton of work to do it. The electronics side is the tricky thing unless you're a wiz at that.
The Following User Says Thank You to Daox For This Useful Post:
aerohead (02-05-2021)
