Old 11-20-2019, 04:07 PM   #12 (permalink)
mpg_numbers_guy
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Now you'll never have to change the brakes again!
Will you continue your tradition of putting a boat tail on every car you've owned with the Mirage?
If I had a Mirage I would definitely get the UK-spec final drive and use it with the US-spec gears - IIRC the UK is the one with the taller final drive and the US has the shorter final drive, but a taller 5th gear? But that would probably be expensive, sooooo.
I probably wouldn't go with taller tires, because RE92s. It would be interesting to see whether taller gearing + not as LRR tire or stock gearing + RE92s is best for FE.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
Xist (11-21-2019)
