Thread: Tow bar angle
Old 11-20-2019, 08:22 PM   #3 (permalink)
EcoCivic
Originally Posted by Gasoline Fumes View Post
I had no stability issues at speed with this setup, but the bar was pretty level and the Insight weighs a lot less than a Jetta. Got both of my Insights home the same way. I did have issues with oversteer on icy roads. And some issues making tight turns at low speed. Flat towing a car sucks. I'd do it again if I had to, but I don't want to!
Thanks. Do you think my hitch is low enough to cause a stability problem? Maybe getting a taller mount for my ball so the tow bar is more level would help?
