Once I know the engine isn't consuming hardly any oil I will get expensive plugs. I'm running lower than normal tension oil rings so I may have to take care of an oil issue or 2.
Also have a carb warm up plate in case the eldelbrock rpm air gap dual plain intake manifold keeps the carb too cold in the winter.
