Old 11-26-2019, 10:01 AM   #73 (permalink)
Daox
Originally Posted by teoman View Post
Put a cardboard box over your printer. That will provide thermal stability to stop warping of the parts.
If you have delamination you may need to up the extrusion temperature.
Thanks for the tips. I actually just finished printing the bottom plate this morning. I lowered the extrusion temperature as much as I was comfortable with, raised the bed temperature a good amount, and used a 10mm brim on it. It looks like it came out pretty good.
Originally Posted by mpg_numbers_guy View Post
Time to get LED headlights!
I have certainly thought about it. The LEDs I have used in the past have worked okayish. Decent light output, low power use, good low beam, but horrible high beam pattern.
The Following 2 Users Say Thank You to Daox For This Useful Post:
Ecky (04-20-2020), redpoint5 (11-26-2019)
