Old 11-28-2019, 12:29 PM   #7 (permalink)
grins2go_brett
grins2go_brett's Avatar
Diffuser vanes are something I've considered adding in the future. But that's not the area I'm concerned about currently. I guess I didn't explain very well. So here are a couple of pictures about the area I'm talking about. In these pictures behind the tire at the top is the inside of the wheel well. On the bottom left, you can see the framing and coroplast of my belly pan which is attached to the bottom of the body panels. I'm trying to decide if it's worth it or needed to extend the wheel well walls down to the level of the belly pan...as much as can be done around the suspension. Just wondering what others with larger vehicles and gaps like this have done. Thanks!
ID:	27255   Click image for larger version
