Shifting question: First second then fifth, or use every gear?
I've gotten a Honda Jazz 2003 with about 251,000 km and first tank I've managed 40mpg with mainly 80-90km driving.
If I am starting in a 80km zone I will go from first gear, second gear then into fifth gear when I am around 60km per hour until 80km cruising speed.
If I am in 60km zone I go first, second then fifth gear around 50km per hour up to 60km cruising speed.
This changes slightly if there is a hill and I need a lower gear than fifth.
My sister says I should use every single gear and not skip any gears.
I think that's silly.
What do you think?
