Old 12-02-2019, 11:35 PM   #4 (permalink)
oil pan 4
Well there's a lot that goes into spool times.
Compressor size, trim A/R, turbine size, trim and housing type and A/R, oil flow to the turbo, bearing type volume of piping and intercooler.
If you only intend to run single digit psi then compile a list of smaller turbos that have a high trim number on the compressor. Those will be more efficient at lower psi and will move more air faster at lower engine loads.
