Old 12-03-2019, 01:02 PM   #6 (permalink)
Grant-53
Decide what speed and range you need. Expect the battery pack to add at least 1000 lbs to the weight. Do you plan to use a transmission as that will affect the motor specification? Capacitors can help with the large current draw at start up. Consider the charging systems available.
