Old 12-07-2019, 12:27 AM   #36 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
If it's still bucking after EGR plate clean you might need a new EGR valve as well.
You want the Dorman one with part number 911-756
You want to avoid most of the EGR valves out there. Most of them have a smaller opening which can cause you to get P1491 check engine light because the passage is too narrow.
I haven't tried this one but the valve passage looks to be the same as on the Insight, maybe this one works fine:
https://www.ebay.com/itm/GENUINE-OEM...MAAOSw9a5XPrDx
It's cheaper than the Dorman I referred to above.
The Following 2 Users Say Thank You to Natalya For This Useful Post:
Gasoline Fumes (12-08-2019), Xist (12-10-2019)
