Old 12-08-2019, 12:27 PM   #38 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Natalya View Post
If it's still bucking after EGR plate clean you might need a new EGR valve as well.
You want the Dorman one with part number 911-756
You want to avoid most of the EGR valves out there. Most of them have a smaller opening which can cause you to get P1491 check engine light because the passage is too narrow.
I haven't tried this one but the valve passage looks to be the same as on the Insight, maybe this one works fine:
https://www.ebay.com/itm/GENUINE-OEM...MAAOSw9a5XPrDx
It's cheaper than the Dorman I referred to above.
Thanks! Can the EGR valve be tested? I prefer not to buy parts unless I know I need them.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
