Old 12-08-2019, 01:42 PM   #6 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I like these cars--I thought about getting one when I bought my Prius, and sometimes I wish I did just to have a manual transmission again.
Originally Posted by BarryKillahWhale View Post
-Front wheel skirts
-Front aero underbody panel
Just a terminology note: "wheel skirt" usually refers to a covering over the outside of the wheel arch; what you're referring to are usually called wheel strakes or wheel air dams or similar.
I looked back through my pictures and remembered that I had inspected the underside of the Focus at the 2018 Indianapolis Auto Show. It uses the same wheel strake design as the Fusion and C-Max Hybrid of the same year, which is larger than most cars', made of flexible material rather than rigid, and segmented:
The C-Max has additional fairings on the front and back that would be an easy retrofit to your car:
They're cheap, too--$12 for the front and $18 for the rear. Ford introduced these in the second year of C-Max production in an attempt to improve the C-Max Hybrid's actual MPG compared to its EPA rating (which owners complained about when the car was introduced--the EPA investigated and the ratings were subsequently lowered from 47mpg combined to 40mpg).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 4 Users Say Thank You to Vman455 For This Useful Post:
bespurcell (01-08-2020), MetroMPG (01-08-2020), MPGomatic (01-09-2020), oldtamiyaphile (12-08-2019)
