Just don't put it on a lift with all that weight.
I don't know how much the cap weighs. I wish I did, but had no luck looking for weight stats on these. They were all built to order with many different options, so it would be tough to figure out without a scale.
While it definitely feels heftier than the cab-height fiberglass cap it replaced, the older gent I bought it from and me were able to lift it off of his truck and onto mine without help or undue strain or injury. The cap is built from 1x1 aluminum square tubing with .035 aluminum skin and a few aluminum extrusions forming the corners and hinges. My first deflector will likely be made from .040 aluminum, because I happen to have a decent-sized piece of it.
The curb weight of the 2WD Ranger Supercab is around 3,300 lbs, so I doubt it will even hit 4,000 lbs. post-modifications without a significant load onboard.
