Old 12-09-2019, 05:26 AM   #44 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Natalya View Post
If it's bucking in lean burn and you cleaned the egr passages then the egr valve is the main culprit. I'm not sure if it could be something else. I don't know how to test it unless you have a friend with an Insight and a good EGR valve you can try who lives near you. It's not super hard to pull the valve out.
I've tried unplugging the EGR valve and also replacing it with a block-off plate. Still had the bucking.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
