Old 12-10-2019, 10:00 AM   #71 (permalink)
Joggernot
Joggernot's Avatar
Originally Posted by Plasmajab View Post
Weirdly enough.. My trucks door panel says 35 psi. But I noticed on my last ones that the outer edges on all four tires are worn.. I religiously kept them at 35, but now Im at 40 to see if it makes a difference in tire wear. Regardless of the fuel economy.
I have always run max sidewall pressure in a pickup. If it says 51 psi max, run 51 psi. If it says 80 psi max, run 80 psi. Never had the outer edges or the middle wear faster. YMMV.
