Old 12-11-2019, 02:39 AM   #3 (permalink)
M_a_t_t
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Is the ground plane moving? Are the wheels represented?
They interoperate, or something. There should be some algorithm to combine the results.
Is this analyzing a 2D plane though the centerline of the vehicle? If so it's meaningless. The entire 3D form is necessary.
The only difference I see is the speed and pressure. What hood height difference is there? Once again, the 3D form is significant. A Jeep and a VW Beetle have flat windshields at a similar angle. But the Jeep's is square while the Beetle has a teardrop that has been truncated at the front. It's body is widest at the C-pillar.
edit:
I looked around a bit. You may find answers at www.cfd-online.com/Forums/autodesk-simulation-cfd/
1.Ground plane is stationary as well as the wheels. Same as in a wind tunnel.
1.5 Would that algorithm be the cD number or similar?
2. Can you expand on that? Other threads look at 2d profiles, which would be basically the same as a smoke overlay (like in the first post of the wind tunnel thread) and we still can make assumptions based on that data such as how small the vortex at the back of the car is. I just want to try and figure out how much difference it makes and have a plan before trying to make something on the car.
https://ecomodder.com/forum/showthre...ead-26678.html
3. Its relatively small. Like 3-4 inches up the windshield. I only put it in the center of the model because thats where the plane is. Jeep and beetles have different approaches though. Jeeps hoods are pretty much parallel to the ground. Ignoring the part at the base of the windshield the beetles is more obtuse.
I will check that out, thanks.
Wind speed set to 25 m/s. velocity instead of pressure.
Wind speed at 25 m/s velocity instead of pressure. It also seems like flow stays attached longer at the back.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
